Sven
Seglare
You might remember that one or two years ago Glyn mentioned using a 1-gallon SS Hudson insectecide sprayer as a shower. The idea was that you put the sprayer on the stove to heat up the water and then used the pump to set it up for spraying. I went to OSH and picked one up as soon as Glyn posted his idea here, but we didn't actually use it until last weekend.
Imagine my surprise when I found out how well it works ! So far we've only used it in the slip to clean the dishes, but it will work great for taking showers too. I put in a gallon on water, put it on the Origo on high for 8 minutes and the result is wonderfull warm/hot pressurized water !
Now I've got to come up with an easily stowable and deployable enclosure for the cockpit so we can shower in port in the cockpit (with the companion way closed) and then step down into the cabin to dry off and get dressed.
Thanks Glyn !
-Sven
Thanks Glyn !
-Sven
