Ian S
I'm in the process of stripping 15 yrs of paint of my e-27. the previous
owner(s) obviously stripped it down before and did a fine job of over sanding. As I am now sanding I am finding if I go through the white gel coat there apears to be a layer of resin that is green proir to the first layer of glass. Not sure what to make of it. Why would ericson tint the resin or was the boat gelcoated green originally? The other question is now that I'm sanding alot of green pock marks are showing up. it seems as though they may be small blisters that have caused the first coat of resin to stand up and now that the gel coat is so thin they are showing through. The spots are not soft they do not chip away easily, are these blisters? Odd as well, they are only on the port side of the hull? Has anyone seen this? Is the gel coat now so thin that I require an epoxy barrier? If these are not blisters can I just paint the hull? I was hoping to use vc17 over the bottom and was told just to scrape and sand of the old paint and apply new, DONE! seems to simple to me? I would greatly appreciate any and all experience and or opinions.
