Chuck Cooper
I have owned my 1978 Ericson 27 for about two months. I want to replace the tiller with wheel steering. It seems that the contractors l have called are either to busy or not interested as they have not called back. If anyone has had experience with installation of a wheel to replace the rudder l would appreciate hearing from you. I want to know if this is a project l can do or should l continue my search for a contractor? Is there a special model wheel that has been designed for E27?
Also my main sail and jib halyards are orininal equipment and in need of replacement. They are both steel cable to rope design. I want to replace them with all rope halyard. Will 3/8 inch rope halyard fit through the roller that the cable now passes through at the mast head?
Thanks for any help out there.
Chuck
Chuck
