I am in the market for an Ericson 27, 28, 28+, and might consider a 29 or 30. I was wondering how do these models sail? Are they tender, tippy, stable, are they well balanced?
Also, are there any problem areas that I should be looking for when inspecting a potential boat? Are they prone to blisters? Soft decks? Any years to avoid?
Any info anyone can offer would be great!!!
___________
I am probably guessing wrong... but the way your questions start out, I worry that maybe the words "tender, tippy, stable, and well ballanced" are sort of grouped together...
They are not all the same, though.
As I would try to explain it, You start with stability -- there is initial and final. Any boat with slack bilges will have less initial, i.e. it tips some when you step on board. This same same boat may easily be Very Stiff when heeled to about 12 to 15 degrees. At the other design extreme are the boats with more of a hard chine shape-change where the more vertical side turns at a sharper angle to the bottom shape. These will be very un-tippy when you step on board, but when they finally yield to enough wind pressure they heel a lot.
Most of the Bruce King Ericsons (and the earlier 26-1 and 35-1) have a deeper bilge and a sump and will heel a bit when you step aboard. And, they will stiffen a LOT as they heel. The more slack bilge and good V sections forward give you that soft landing when confronting big seas and will keep you comfortable.
All of the Ericsons (and Olson's, for that matter) have enough of a ballast to displacement ratio to be considered stable and safe. I freely admit that the flatter bottom on my Olson gives a harsher ride in steep seas, and that's the price I pay for double-digit speeds...
"There's no free lunch!" as the madam lectured the Nevada legislature many decades ago.
"Balance" is the part you will Really Love when sailing an Ericson. Most of the models you are shopping for are genuinely fun to sail, with a soft touch on the helm. These are boats that are just as much fun to sail with the tiller versions as with the wheel.
As to problems... any boat from any builder can have some bottom blisters (usually not a big deal) and any boat could have water intrusion in the deck if the past owner(s) have not rebedded deck hardware regularly. The survey will tell you what you need to know.
Let us know how your search goes, and feel free to share your thoughts as you refine your goals.
Best,
Loren in PDX
