I'm thinking about moving my mast winch from the jib side to the main side. I now have roller furling and don't really need the jib winch, but I'm having problems getting my new main tight enough in the luff.
The winch is mounted to a wooden curved block that wraps around the side of the mast. It looks like the only way to remove the winch from the block is the small allen head screw/bolt in the center (top) of the winch. Is this the way to do it?
Also could I just move the whole winch/block assembly to the main side with no problems. I've read something about a compression post needed for mast winches. I don't really know what that is. Maybe something inside the mast (and already there for the jib winch)?
