Hi,
Today I noticed a crack about 2" in our Yacht Specialties pedestal, and am looking for advice on how I can fix it properly. I can't post a picture, but will try to describe it.
It looks like the top piece that holds the instruments is made of fibreglass, and it sits on two stainless steel posts above the compass. The crack is in that top piece that fits on the two 1" stainless steel posts, above the compass. It is in the section where the fibreglass forms a tube into which the stainless steel post fits, right at the base of the fibreglass, stretching up about two inches from the top of the stainless steel post.
I think the best way to fix it might be to widen the crack a bit and repair with Marine Tex. Then I think I might drill a hole through the fibreglass piece into the stainless steel post and insert a machine screw to hold it together a bit better than it currently is. I could countersink that screw and cover it with Marine Tex as well to make it invisible, but that would strengthen it.
Does anyone have any better ideas?
