Hey all, I am hoping to make it out and looks at a 35-5 this weekend, and am looking to see where the usual problem areas are that I should give a close look. From checking the forums, looks like there is some leaking issues around the dorades into the cabin people have complained about. What else?
Anyone have comments on how easy one of these is to single hand in the usual/close to factory setup?
How is the deck/hull joint setup on this boat, is it in inward flange with some goo and then through bolted? if so, anyone know the spacings? Whatever boat I end up getting I would like to do some off-shore stuff with it, so if people have done similar retrofits, that would be helpful as well.
Any of you northwesteners been on the boat for sail up in seqium called 'Mariah'? and know if it's condition?
Thanks much for any help!
Lauren
Lauren
