I just received an Indigo 3 blade prop I ordered for my E27 with Atomic 4. The good comments from owners on this forum made me decide to try it.
I noticed the instructions recommend using some valve grinding compound when installing it to get a good fit between the hole in the prop and the shaft.
I was planning on probably having my diver install it while my boat was in the water. Obviously using the valve grinding compound would not work in this situation. However, since my boat really needs a bottom paint job, I might be better off hauling and doing both at the same time.
Anybody else just install their Indigo prop while the boat was in the water?
