phil bennett
1983 E-33RH. i've got no reading on kph instruments and think it's a clogged impeller. I've not removed it with the boat in t
he water. how do you do it?
If it is a plastic thru-hull I would be concerned about breaking it with a wood plug. How about using a sponge tightly stuffed in there to slow the water down? I think you can get spongy thru-hull plugs too.so use a standard wooden universal plug
Phil, you might ask the former owner, before the most resent owner. He might recall where the plug was last stored. That impeller might have some slime or weed clogging it.1983 E-33RH. i've got no reading on kph instruments and think it's a clogged impeller. I've not removed it with the boat in t
I've used a wooden plug with no problem. Insert with a twist, and don't force it too hard, and it should stay in place, perhaps with minor leaking. Of course, you shouldn't leave it unattended, unless you can secure the plug positively. I've since replaced my transducer and the new one included a "dummy plug" for this purpose.so use a standard wooden universal plug?
