Permanent Lazy Jacks.
Don, I tend to agree with Rob, as my Lazy Jacks are fixed and don't collapse to the mast. I too have had my sail cover modified to accept the lines and don't find it difficult at all getting the sail up through the lines. The trick (if you'd call it that) is to motor dead into the wind and raise the sail with the main sheet very slack which allows the boom to move one way or the other as the sail goes up. I also find sometimes that a slight push helps the boom to move into place. I should say that my lines are led aft so positioning the boom is no trouble, but it occurs to me that one could do the same with the boom if standing at the mast. An anecdotal story emreges here. I had a new cover and a bunch of other canvas stuff made in June while attending the NW Ericson Rendezvous and told the chap not to make sail cover until the brand new main was done and on, and until I added a fourth set of Jacks at the aft. Well he went ahead anyway, had to then add 3 inches to the bottom of the cover (looks fine) and also had to add the keyholes for the last set. So I'm standing there in the boat on the port side of the new sail cover showing him where I wanted the pair of keyhole(s)....."I want it right here". A week later I met him at the boat to see the new keyhole, was happy and gave him the second half of the check (total was $5,400.00). A week after that I took the cover off to go sailing to discover that he'd only added one keyhole to the port side, just where I'd indicated, but not a matching one on the starboard side. I'd given him the other half of the money when seeing the seventh one (assuming that there was a mate to it on the other side) and almost four months later he's still refusing to return my calls to come back to add the eighth one. He used the most expensive and thickest, top-of-the line isingglass(sp?) window material but it has ripples in several places and he refuses to fix that, or to add the three lousy snaps we agreed on to the edges of the insert between my new Bimini to new dodger that he also made. So it's off to another canvas place to have cockpit cushions made and to have the keyhole and snaps added. Alert to locals: Don't deal with Leon's Canvas Shop, rant over!! Glyn, E31 hull #55, Marina del Rey CA
