sv.islandgirl
As other E27 owners have posted here I am receiving a considerable amount of topside water entering the cabin via the chain plates. For those not familiar with the E27 there are 3 chain plates on each side of the boat. Each chain plate has a stainless steel trim plate (perhaps 3 inches long by 1 inch wide) that slides down over the chain plate and attaches to the deck with 2 screws (not thru bolted as there is no access on the inside). It appears that the previous owners attempt to stem the flow of water was to tighten (over tighten) the screws holding the trim plate to the deck. My plan is to fill the void around the chain plate with boat caulk, make a rubber gasket to fit between the trim plate and the deck, and then tighten down the trim plates. Sadly many of the holes for the trim plates are stripped out. What advise can anyone provide to fill the existing holes with some material and make it so that I can tighten down the trim plates? Thanks in advance.
