sailor11767
I thought about hijacking my thread about livability, since it's all about the same boat, but figured a thread in Maintenance was more appropriate. I'm looking at a 77 E35-II that I started off looking at because it was local, even though I didn't want that particular boat. It's insanely priced (down to $29K, worth under $10K), but I'm figuring it doesn't hurt me to put in a real low offer and let him decide. But, the more I look, the more I have questions.
* She's got the unfinished teak interior, so she clearly shows any water leaks. And there are many. The entire hull to deck joint shows signs of water leaking, (despite Jack Horner's comment that it is a good joint). Is this a problem? Or just clean and re-oil the teak? If it's a very slight nuisance leak with no damage to deck core, I can live with it.
* Every single port shows signs of leakage. The opening ports, I could understand. But the fixed ports as well. Is this an invitation to core rot?
* The chain plates are at least 95% intact. A bit of staining, but NO significant bulkhead rot. Do I have deck problems to go with it?
* There's a lot of information here on refurbishing the ports, and that makes sense on the fixed ports. But, the "opening ports" (they are in horrible shape, and slide rather than hinge) are likely candidates for replacement. Since Defender charges just over $100 each regardless of size, has anyone made them a little larger? How well does that work?
* The hatches seem to be in functional condition. They appear to be "home made" (by Ericson, but not commericial hatches). Do they respond well to a little TLC, or even a complete re-build of the hatch (should be an easy job)? Or, does someone make a drop-on replacement?
* The companionway hatch is very tired and rotten as well. There are discussions here on making a new one, and that is do-able. But, has anyone ever had a piece of 1/2" acrylic bent to the curve, and used that as a starting point? Looks like it might be a really good place to start, very low maintenance, and adds even more light below decks.
* The cockpit cubbies are rotten. Does that wood provide anything more than a flat surface to put things on? Or is that a bad sign? And, if I drill out all the plugs and remove the combings, does that make the replacment project easy?
* The mast is ugly as sin. Not damaged, just aesthetic. Somehow, the anodizing has been damaged. Looks like someone used some sort of cleaner on it, and it now shows all kinds of streaky, swirly marks on it. Any thoughts? I suspect "ignore it" is the best answer, followed by "remova mast and all hardware and have it painted."
* The rubrail inserts are damaged and partially removd. I see that Wafco still makes and sells the inserts, and that can be done for around $400 or less, which is an easy answer. But, has anyone ever removed the entire plastic system and replaced it with a wood (roughly 2x2, but with some shaping to it) and SS strip rubrail? It sure looks like an easy, relatively inexpensive, and high return project.
* Parts of the bottom of the keel has been repaired with fiberglass cloth, very poorly done. I suspect that they looked at some grounding damage, and tried to fix it. Can it be ignored? I'll be crusing. I'm sure that a week with the boat in the slings, laying on my back with a grinder, epoxy, and roving would make a bang-up repair job.
* The boat has bunches of plumbing for the head. I see a diverter valve, thru-hull, deck pump-out fitting, even a small diaphram pump to move things when there is no pump out station. Notice I did NOT mention a tank. The hoses that went to/from the tank just stop. Where is a good place to put a tank, and how big can be put in?
* I'm seeing small cracking around the perimeter of the transom. I'm thinking it's no big deal, but my G/F is nervous. Any thoughts?
* Has anyone done any removal/reinstallation of the headliner? There's a few small issues with that, and cleaning it up would be a good thing.
* The main is essentially TRASH. Maybe it's enough to let me get a few sails in for the first season, but it needs to be replaced. It has been uncovered on the boom for over a year. Add to this the fact that the boom is uncomfortably high. I can stand up in the cockpit, and my head clears -- but more importantly, I don't know how I'd ever get that high to furl it. So, since I need a new main, has anyone ever moved the boom down 2 feet, added 2 feet of main track (can you get it?) and made a 2 foot higher main? Sounds like a win-win situation.
* All the interior cushions are in sad shape. Anyone have a rough idea on the price for a wholesale replacement on a settee layout E-35/II?
Oh, and has anyone found a way to do a search here with multiple words? The more words I add (google makes more words a SMALLER search), the more respsonses I get. "Boom Height" gives many more responses than "Boom"
Everyone pick an item and answer, and this will be a great thread!
Harry
Harry
