Looking for Schaefer 1-1/4" mid-rail cleat (70-75)
Kadima
Hi! Looking to see if anyone has a Schaefer 1-1/4 mid-rail cleat they are looking to part with. It is the cleat typically used for the spring line. Thanks!
bgary
Advanced Beginner
I've got one and love it. Works great, but (as you likely know) not cheap.
That screw knob on the Garhauer was a bit annoying but was still better than nothing. I wish Garhauer (or some other company) would make one that could be semi-permanently mounted with a secure flush mount bolt or something. The pin on the Schaefer doesn’t give me great confidence.
True. Hole in the horn and a flush allen head screw to fix it to the rail should do the job. Schaefer description also has this: "They will not fit earlier versions of T-Track or some competitors models."
Barton also does one at an attractive price: https://defender.com/en_us/barton-sliding-cleat
We've got one on our boat and it fits just fine. On the other side is a ratty old aluminum thing that is barely big enough. Another Schaefer has been on my wish list for over a year, but hard to justify. - The $145 model you link is for 1" track. The 1.25" model is $155, still less than I've ever seen them. I do like that these are a solid casting, far less likely to come apart.
As little as it gets moved, something like you describe with a couple flush screws would be very nice. Eliminating that articulated pin should drive the cost down. If I were feeling ambitious, I'd make a pattern and get some cast.
AK67
When you do get around to it: Flush screw(s) with a flange so they can't come loose and fall overboard. haha.
