The jib car track on my 1971 E-29 is loose. It has 1" track mounted along the rail with flat head bolts. In some places the bolts are loose and the track will lift off the deck slightly if the car is located at the spot. When I tried to tighten the bolts the nuts spin. I can't get access to the nuts as they are glassed over at the point where the deck is attached to the hull.
Has anyone experienced this problem? Anyone have any ideas on how to correct this?
Dave
Dave
