Jim Picerno
1989 38-200
I spent the last two days getting my new boat in the water. Dealing with lots of oddities (e.g. some mast lights connect to a terminal block on the coach roof, while others run to the bottom of the mast). If you look carefully at the attached photo, the bow looks to be riding very low in the water. I've not placed anything under the V-berth yet, but the boat is suppose to have 200 ft. of 5/8 G4 chain along with a windlass. The chain plus 75 ft. rope road sits in the chain locker forward of the V-berth. I assume this is the culprit for the bow riding so low in the water. So, some questions. Are you carrying this much chain on your boat? If you're carrying a lot chain, have you modified the chain locker to store the chain further aft, below the V-berth? Any other reason why the bow is riding so low? Thanks.
