low engine rpm
Herb,
My diesel book ("Troubleshooting Marine Diesels", Peter Compton) says that if the rpms get within 10 percent of expected, the most likely cause is overloading.
In order of likelihood: dirty prop, dirty bottom, prop shaft binding, wrong prop, wrong transmission ratio.
Or the cause may be poor fuel supply, in order of likelihood: injector defective, air in system, contaminated fuel, water in fuel, control cable restricted, extra washer under injector, injector pipes leaking, lift pump defective, injector pump contaminated, fuel tank vent restricted,
With dark exhaust smoke: restricted air intake, restricted exhaust
Personally, when I run into the problem of something falling ten percent short of expected, I have learned to do nothing for a while. I learned it from my wife, who says it is why we are still married.
HerbertFriedman
Christian, thanks for the info, lots to check. I dont think the problem lies in the drive train, prop, dirty bottom etc. because I cannot get the engine to rev beyond 2500 rpm a the dock in neutral, hence I changed the exhaust riser elbow, it was not changed for 18 yrs and the engine had 1200 hours since the last replacement. Since changing the elbow did not solve the problem, my concern turns next to the fuel system, i.e. injectors.
But I do like your advice about waiting a bit, my wife thanks you as well.
Pat O'Connell
Hi Herb Hi Christian
Thanks....I am suspicious that you guys know something about boats. I'm positive that you know a lot about marriage! :<{)))
Best Regards
Pat O'Connell
Ericson 28+ Universal 5411
Ian S
Another good reply from Christian. Break it down into order of likelyhood. Trouble shoot accordingly. I confess I never considered the tach being off!
He's only getting 2500 in neutral so that eliminates any loading issues. Possibly max throttle position adjustment. Check the paint on the locknuts. You will be able to see if they have been moved / adjusted. Generally this is nothing that is adjusted / moved in the life of the engine. it is set at the factory and thats it. most are safety wired. For other owners I would not be so quick to go after exhaust issues. It takes a really clogged exhaust to hurt performance. These tiny displacement engines produce little exhaust and you can get all the flow you need out of 2" exhaust with a 300+ cui. engine so bear that in mind. Remember as well that just BC the valves were adjusted does not mean they were set correctly. Takes all of 15 minutes to confirm the clearances. I still insist a compression check is in order. Keep us posted hopefully you will get this resolved without incurring to much expense.
Capt. Ian
HerbertFriedman
Ian, I did check out the throttle cable. I loosened the check nut and backed off the adjusting screw about one turn and saw little difference it the rpm, maybe 2550 but still way short. Time to call in the experts and have a pro mechanic check out the engine. I did have he valves adjusted about 3 years ago but this low rpm problem just started recently so I think the valves were adjusted OK at that time but the adjustment could have slipped. Will let you know what the mech finds out.
Just for the record, what should a normal M25XP rev up to in neutral?
Ian S
In neutral I would not have a guess. way over red line especially since these are pure mechanical diesels and have no rev limiter that i know of. well over operational rpm. the maximum figures stated are what the engine should rev to under normal loads at hull speed. back to the throttle. to be clear i am not speaking about the cable in any way. the cable operates a bell crank that translates that movement into lateral movement to a rod with two ball joints. that actuates the fuel timing pump. there is an idle stop nut and a max throttle stop nut. these are the components I'm referring to.
Capt, Ian
HerbertFriedman
Bob, thanks, I thought getting only to 2500 rpm in neutral was kinda low. Let's see what the diesel maven says, hopefully next week,
Odelay
Herbert- any update on what the low rpms were caused by?
I’m having a similar issue—except my boat when in gear won’t rev up past “neutral” rpms
Things I have tried so far
-just had the prop cleaned to rule that out.
Fresh diesel, fresh injectors, all new fuel lines and lifter pump with updated RACOR prefilter.
New mixing exhaust elbow—( that thing was plugged last year when I changed it.)
She didn’t smoke really bad when running— normal grayish exhaust mostly.
Should I be concerned about the muffler being plugged? When do we know that needs to be changed?
Probably a naive/dumb question, but have you verified that the throttle cable is transferring movement to the attachment point for the injectors?
And by "all new" fuel lines, do you describe the hose from the tank outlet all the way to the lift pump? Going out further on a thin limb, are you certain that the fuel exit fitting on the tank is clear of gunk or debris? (I hope that was no internal screen put there at EY, like Catalina unfortunately used to do.)
And... is the fuel tank vent hose in good shape and the little metal hull fitting that it is plumbed to-- clear and clean? i.e. no mud dauber wasp nest inside? :(
gabriel
Live free or die hard
Did you change the secondary filter? Being the finer of the two it’s the one that likely to get plugged and restrict fuel flow which leads to low rpm under load.
If you have the air bleed knob on your injector pump, make sure it's closed all the way. If open too far it lets too much fuel bypass to the return line, and robs the engine of fuel needed to reach higher RPMs.
Odelay
Bleed knob is closed
Odelay
IMG_8106.jpegWell well well, a mechanic finally showed up after multiple attempts resulting in no shows and hand offs. it turned out to be valves way out of adjustment- and this little lever on the valve cover being turned 180* (likely caused by me when I was wrestling around with the exhaust elbow)
The valves had been slapping against this rod under the valve cover, and weren’t able to fully actuate.
“Full speed ahead captain, Odelay let’s go!”
2500 is a rather low RPM for the top end. It sounds like the engine is overloaded in normal usage. Mine spins about 3200 at max and I cruise at about 2500. Has there been a prop change? Is the prop overpitched?
An over pitched propeller could also be the reason that you are having to replace your exhaust elbow. I don't think that, if it is fouled that it can be "boiled out" like a heat exchanger. That soot become hard as stone--I have tried unsuccessfully to chip some of it out.
Odelay
“UPDATE”
Ok-after having the same issue with RPMs in gear this last year- I looked into more solutions and read through all the manuals I could find.
I had replaced the raw water pump a couple years back and just above the pump is a “fuel adjustment screw”
the new pump made it so the lock nuts on this screw were not secured properly.
I think what happened was it vibrated into the block and was restricting fuel.
I have since unscrewed it and am getting great performance from the engine.
Now I need to find a solution to keep it locked into place.
