I have a 1987 E-28 with the original M-12 universal diesel motor.
I would like to replace the current low oil pressure idiot light with a proper oil pressure gauge. I assume I need to replace the idiot light sending unit with something different.
1. Where would I buy the new sending unit?
2. Would a new sending unit be compatible with a used oil pressure gauge or do I need to buy a compatible gauge? (I have a used gauge already.)
also my water temp gauge reads low. I will be replacing the thermostat this spring and may want to install a second water temp gauge in the engine compartment. Would the second gague just wire up to the same sending unit as the cockpit guage or do I need to do something special for a second gauge?
Thanks in advance
Joe
Thanks in advance
Joe
