M-18 coolant flush question
light24bulbs
E30+ 1984, San Juan Island, Wa
Where the @*$& is the coolant drain plug?
Apparently according to the manual it's "above the oil filter". I just can't figure this out without a visual aid.
light24bulbs
If anybody else stumbles upon this, I ended up just taking off hoses in low points and draining the coolant that way, I seemed to get almost all of it. I had to anyway.
Messy but physically possible.
Second Star
You appear to have an Oberdorfer raw water pump; my M18 has a discontinued Sherwood M5. Do you know the model of pump you have?
Should be easy enough, but messy, to install a short length of pipe with a quarter turn valve where that plug is to make future coolant changes simple. I added a two foot long piece of hose after the petcock to make draining into a container easier.
