Best practice for a "wet" winterization of the raw water cooling system would include running a couple of gallons of antifreeze through the system as part of your final shutdown. Running it dry will have a negative impact on your impeller and other parts of the system not to mention any trapped water in the system could freeze and cause expensive damage. The
Universal M40 manual (also found on in the
Resources section on this forum) has the procedures you should follow.
You'll want to get the pricier glycol-based pink RV antifreeze (easiest way to tell, apart from ingredients, is the alcohol-based has combustible warnings on it). I've found that Menard's has the best everyday price on it (I see you're based in OH). Expect to pay $5-6 gallon, but it's cheap insurance in my opinion.
