Gmilburn
Hi all,
I'm wanting to run the main halyard from the mast back to a cabin top winch--to be able to hoist the main--without going forward. It appears that the previous owner had it rigged that way as the winch and cleat are there but the blocks at the base of the mast are gone and screws remain (either that or this is a stock option on an E29, and the screws have been there since day one). I have attached a photo of the mast (to the left) and the screws. Regardless, I need help in choosing the two blocks that 1) make the rope halyard make the turn from the mast at the cabin top and 2) make the turn back to the winch and cleat. I want to use the existing holes. I've spent time on the Schaefer and Harken sites and the plethora of blocks and options, leave me more confused. So far I think I need a Halyard Lead Block (also called a Lift Block) and a Turning Cheek Block. However, my gut says I ought to be looking at a spring upright block, to twist and turn with the various stresses. Any help or suggestions would be greatly appreciated.
Thanks, Gary
"Hydrophilic" 1977 E29 Hull 515
Thanks, Gary
