Previously, I'd asked about the first thing you'd do as a new owner. I started looking at projects and so forth and saw some phenomenal work and workmanship!
So. I generally sail single-handed, or with crew whose primary function seems to be deck candy. I don't have anything against deck candy, mind you, but lashing the tiller, running up to the mast and hoisting the main, running back to the cockpit, (hopefully before the main catches air or decides to do a short jibe), trimming the main, then hauling the genoa, while my deck candy watches is rapidly becoming my second least favorite thing to do. Deck candy training is NOT an option. (First place goes to watching a beautiful sailing day through my office window.)
Has anyone with an E-27 done a conversion from the mast winch to a winch/clutch combination reachable from the cockpit? I've seen installations in some of your photos, and it looks possible. Obviously, I'm concerned about the load on the cabin overhead, as well as mounting the block(s) at the foot of the mast.
As always, thanks, in advance!
Matt Nunes
SV Finally
Matt Nunes
SV Finally
