Actually I called it "straightforward wooddorking". The hardest part
was laminating the panel. I still want to reiterate that vacuum
bagging would be my first choice in a home shop. Building the setup shown
in the photo with all the clamps and cauls is a do-able, but inferior method.
Notice that there is no clamp deep enough to reach out to the middle
of the panel. Instead, he has resorted to laying boxes of tile on top
of the cauls. Vacuum bagging gets around this problem.
Anyway regarding the slides I mentioned, I cut teak wedges into roughly
2" squares and located them at the 4 inside corners in such a manner that
when placed on the runners, the hatch sat level. These wedges were then
topped off with 2" square pieces of uhmw plastic using a countersunk
screw. I don't remember the exact thickness used but enough so
that the hatch frame was just lifted off the metal runners and riding
only on the plastic. I hope that clarifies it for you.
Martin
Martin
