Startacker
We were sailing in 15-knot winds on my Ericson 30. While tightening the Genoa halyard with the port side mast winch it started to come out of the mast. We quickly tied off the halyard to a cleat and were able to remove the winch from the mast. Upon inspection we found the bolts holding the winch to the mast were only tapped into the aluminum on the mast with no back support.
I want to install 2 - 3/16” aluminum plates, one on each side. Then use ¼” stainless steel all thread to sandwich the mast in between. Then I would tap the bolts into the plate and the mast and reinstall the winches.
I am thinking this would be an adequate base for the winches and actually strengthen the mast. Another sailor told me it would actually weaken the mast at that point. Any suggestions would be appreciated.
