gargrag
@Gaviate my remote is installed on the transom. I’m going to move the remote to were the original controls where. Why? The main reason is that if the prop us aft the rudder, when reversing, it can put a lot of force on your tillerand you will have a shorter harder lever to deal with,Thanks for the pic Guzzi. I also have a 9.9 Nissan but mounted in cutout of transom and am planning to add remote control this season. I was struggling with location as my 27 never had an inboard, and so no clues as to best spot. Maneuvering with separate throttle, shift lever and reversed tiller handle, all at furthest aft point in cockpit has been sometimes challenging, tho always fun. I'm looking forward to "Easy Peasy"![]()
also you get used to the same visual references as you steer always from the same positions in the cockpit
i made up my mind that steering with only one steer while it may require more back and forth or it can limit maneuverability, its safer at least for me.
Good luck installing that remote!
