Hi,
As in so many of our 1980s boats, my 1984 E30+ aluminum diesel tank is beginning to leak/weep/sweat at the very front end bottom middle V, not enough to drip but too much to ignore. I plan to empty the fuel, cut an inspection port as per videos and posts on this site, clean with acetone, then repair in place. Local shops are wishing me luck, but refusing to recommend what sealant to use, I'm sure out of liability concerns. I had planned to use epoxy and cloth, but was advised not to do that as diesel melts epoxy over time. Another mentioned having heard of "liquid metal", but doesn't sell it.
In short, what would you suggest as the best repair material for this minor, but worrying, leak?
Also, for the metal cover on the inspection port, do I need to tap the tank holes, or can I just drill slightly undersize and use sheet metal screws?
Thanks for any advice!
