Hi,
I have done a search and read related threads, but need some more help, please. We recently replaced the transmission on our E30+. The new transmission (a Twin Disc) was slightly larger, about 1" longer and the control lever is on the opposite side from the previous Hurth transmission. So the gear shift cable was routed a bit differently, but seemed to work fine when it was attached, and has been trouble-free for the next two months.
Today, when leaving the dock, the transmission would not shift out of reverse to neutral or forward. I undid the cable at the transmission, and the transmission itself is shifting smoothly. But the cable is absolutely stuck, though it was free yesterday and shifted smoothly.
In looking down the pedestal, the shift lever only moves the cable forward in the pedestal, rather than down the pedestal--a yacht specialties pedestal. I don't know if there is supposed to be something holding the cable firmly in place in the pedestal to let the cable insert move down the cable smoothly???
Also, in looking at the cable routing, both the gear shift and throttle cables come down the pedestal, then beside the hot water tank angling towards the stern and down under the flooring below the steering quadrant, and then out of sight coming forward under the fuel tank to the transmission. This seems to me to be a convoluted routing--is there a simpler way. But I'm also worried that if I change the routing, the cablelength will be off and it won't shift properly.
Can anyone shed light on how I should proceed with this repair?
