hilco woudstra
I have a 1983 3 cylinder Universal diesel in my 35' Ericson, Sketcher.
There is a rubber hose from oil pressure gage-bar to engine. This is just forward of heat exchanger. The small hose then loops over to engine block.
Problem is the termination is below exhaust manifold. Very hard to reach and replace and make sure the clamp it correct.
I had a small leak on the engine end, replaced the hose and clamps. But did not clamp the hose correctly....found out when starting the engine, oil every where.
Had looked for the leak over time, thought it might be rear oil seal. This is a very odd location.
Hopefully no one has a burst from an old line.
Hilco on Sketcher
Hilco on Sketcher
