Olson 34- main sheet pad eye on boom broke
PNW Jeff
Yesterday while racing we jibed without sheeting in the main first- mistake. Gusts were in the low 20s and the pad eye riveted inside the boom to hold the main sheet block broke. I used a couple sail ties and made a bridle on the boom so we could keep sailing.
I’m thinking of a dyneema boom strop to hold the block and spread the load.
Is anybody using something different than the original pad eye they can recommend?
Just an opinion, but if the rivets were old and corroded (aluminum perhaps?), which since they failed apparently were compromised, I'd probably just put the fitting back on with stainless rivets. The connection was the original boom design, I take it.
Some booms use bales, which are easy to install and do accommodate side forces better, especially if the O34 has a single-point mainsheet attachment.
PNW Jeff
The rivets are still there. The bail tore off the stainless plate. No corrosion marks. Just failed in tension due to the shock load. Same thing happened to another olson34 two weeks ago at our club. We have 4 at Portland Yacht Club.
The plate is inside the boom- the rivets only hold it from sliding fore and aft.
I think im replacing the padeye then I’ll put two dyneema webbing straps on the boom and use the pad eye only to stop it moving fore and aft.
I had something happen similar to ours, about two years into my ownership. There is T shape ss weldment. It was a Kenyon idea AFAIK.
In our case, the inside plate had broken on one end of the eye plate which was welded to it.
I took the boom home and took it apart. What with the multi-part purchase for the outhaul and transiting two reef lines and the rope tail for the outhaul, it's kind of crowded in there.
Anyhow, with the broken part out, I took to a local small fab. shop. The guy listened to how the rod put up-force on the fitting, and then welded a reinforcing 'fin' along the top after welding the main firing back together.
Back to the mainsheet question. Our upper blocks (Harken triple) was shackled to an eye strap on the boom. Nowadays I have a line there, connecting to the lower triple about 3 feet lower.
Jeff, does your mainsheet eye extend down thru a slot in the bottom of the boom? Did the boom metal tear? A photo would help some of us trying to form a mental image. :confused:
PNW Jeff
The boom is fine. The eye of the weldment came through the slot in the boom. This is the photo I have of the post break fitting before I drilled it out and a photo of the pad eye plate after removal.
PNW Jeff
Photo showing where the pad eye came through the boom. Ignore the calipers. I wanted to capture the rivet dimension before I drilled it.
Looks like the welded eye was pulled off the base plate (?) If so, and that's a guess, buy a new one and install it...
Dyneema strops seem like an improvement could just use a padeye for positioning/holding the strop where you want it on the boom. I did a Google search a few weeks ago looking at mainsheet arrangements that we wanna try to on a Henderson 30 and came across several Olson mainsheet set ups that are pretty sweet. Here is the link. https://www.olson30.org/boat-setup/traveler-mainsheet/ Something like the 8:1 or 16:1 is what we recreated.
Just visited our boat and brought back a picture of our sheet attachment point on the boom. This may help clarify things a bit.Main Attachment.JPG
O34-Poppy
Sorry for slow reply, but I just joined the site. The bale on my mainsheet pad eye was worn to almost nothing. I actually replaced the boom a couple of years ago to lengthen it, and replaced the pad eye at that time. I switched to a soft shackle at that time as well, with the block attached directly. I don't have a pennat between the block and the bale as shown, because I want as much distance between the top and bottom blocks as possible to maximize the amount of fine tune I have available.
Kelly Robinson.
G Kiba
Dyneema is so strong. When possible, it is good to have a point of failure in the design of wherever you are using it.
Additional data- In 2021, I was replacing my own little custom SS wire pennant, in place since sometime in the 90's. No real-world strength difference, AFAIK. It was a section of vinyl coated LL wire and I swaged an eye on each end.
Also, the pennant has no (zero) effect on the power of the mainsheet system. The system is still 6 to 1. The distance available for fine tuning will never be much over a half foot of vertical space IMHO. The only limitation with sizing the length of the pennant would be running out of adjustment room and "two blocking" the tackle.
To get the length right, raise the main all the way up, and crank the sheet in as far as you can with the BS full on. Then measure how much room you would have for a pennant, and add some just to be safe.
The cool thing is that every foot of pennant takes about 6-ish feet out of the mainsheet you have floating/flailing around during a jibe. Even a couple of feet of pennant makes a pleasingly disproportionate difference.
G Kiba
Loren, I like your technique of sizing the pendent. But you can replace the steel cable with dyneema and make a pendant that is adjustable with lashings and half hitches. Ends up looking very fancy too. I think I ended up with about a 15 inch pendent. Makes gybing so much easier and quicker. I also use a fine tune setup. This is a picture the same lashing I used but attaching my backstay to the hydraulic backstay adjuster (no pic on the ms pendant). I used this same lashing for my mainsheet pendant but using a smaller diameter line. To lash, secure one end with a splice (bottom or top) run the dyneema through both padeyes so you have four lashing lengths. Separate them in to two pairs. run the balance of the line weaving between the pairs pulling each weave snug. Secure the end with half hitches.
bgary
Advanced Beginner
That looks really nice!
(....and, depending on the type of line, may want to consider putting some sort of UV-protection on it...)
G Kiba
The line is UV protected but I have a sunbrella cover when not in use. My mainsheet and pendant are also covered when not in use.
