Okay Electrical Gurus!
I am messing about with my Ample Power NS2 regulator and it allows adjustment of Absorption Voltage, Float Voltage and Absorption Time setpoints. Ample suggests AV at 14.4volts and FV at 13.6volts. I can find no specific information on how to set the voltage setpoints for my current batteries. The house is off-brands that came with the boat (3) wet-cell group 31's, deep cycle, approximately 300+ amp/hrs, and one Interstate heavy-duty group 31 starting battery, new last season, the model Ample Power recommended. General research has indicated that Absorption Voltage at 14.4 volts, Float Voltage at 13.6volts is fairly conservative and that is where I set them. The Absorption Time adjustment is more troublesome. My brief research indicates setting the Absorption Time at 30minutes for every 100amp/hours is appropriate so I set the Absorption Time for a 90 minute setpoint. I would like your input on these settings given my battery bank. Thanks, RT
