John Bouchard
I have been following threads on this subject for a while, as the packing/connection at the top of my E-32-2 (1971) was leaking last season, and I want to stop the leak!
The snow has finally cleared, and so I started to tackle the problem. Regarding the steering system and attachments to the rudder post - I was surprised how easy it was to loosen the cables, remove the bolt through the quadrant and post, and then slide the quadrant up the post. I tied it to hold it up out of the way.
The top plate that "houses" the packing material was easily removed as well, even though evidently it was tightened down as far as it could be... Here is where I have questions! If anyone has a 1971 (my hull is #199) vintage E-32, and has fixed a leaky packing - please respond! Jorge did respond, but I wanted to reach a larger audience! In addition, I'm pretty sure I don't have any cracks or other problems with the rudder tube.
Contrary to what I've seen elsewhere the cover "plate" is held in place by four small bolts, not three, and the packing was only one piece -( 3/8 inch?). The "groove" in the plate seems to be 5/16" wide and 1/4 inch deep. I estimate this by measuring the now square packing.
Other information (dated 11/81!) on this site indicates three overlaid pieces of packing. Is my situation something that was changed by the previous owner, should I use three pieces (although it would have to be much thinner material), or has anyone else used just one piece?
Once the boat goes back in the water.... that's it until the end of the seaso, so I want to make this right as possible!
John B.
John B.
