Piece of rubrail needed
Kranich
E38 owner since 2009
Hi all,
I'm looking for an 8' piece of rubrail for my 38-200. I understand that the rubrail is the same for most 80s Ericsons. So if you have a lenght of the original rubrail sitting around or are planning to replace your entire rubrail with something new and would be willing to part with your old one please let me know.
I bought my Ericson a year ago with a 8' piece of rubrail missing. It came off when the previous owner moved the boat from San Diego to Moss Landing. Must have hit something at sea, so he says. Now I'm trying to replace the 8' piece. I hope that I can find something. Otherwise I would need to replace both sides with something new....
Thanks!
Peter
dwigle
Is this the 2 piece plastic with rubber insert, about 2 inches top to bottom? I have some replacement left over, but it's a little different from the original. My original was gray fairly rigid plastic with a white insert, this is all fairly flexible and white. I'll have to check to see how much I have left over.
Don Wigle
Wiggle Room
E 38 #8
Pt. Richmond, CA
Kranich
Thanks for your replies Don and Glyn!
I'm looking for the solid aluminum rubrail (no insert). I'll try to post a picture soon.
And yes I know that there are alternatives. I just don't want to have two different kinds of rubrail on the same side. That's why I'm looking for a piece of the original. If I don't find it I will replace the whole thing with something new once I have the $$$ for that ;-)
Thanks!
Peter
kevin81
Peter,
Does your rail look like this? This is from a 1989 E34. I need about 9 ft. to replace a section on the port side.
Kevin
1989 E34
Kranich
Yes, that's exactly the one I have. So far nobody has stepped forward and offered a piece. So good luck :)
Peter
