diamondjim
After 2 1/2 months of full time restoration on my newly acquired 1981 28+, I took the boat to the Yard to paint the bottom (first time in 4years). Before the yard, I installed a new Universal M-18 (Z500 kubota diesel), aligned the engine/transmission and propshaft and the machinery functioned perfectly. There was absolutly no pressure on the helm at any speed and no vibration.
During the stay in the yard, I had to replace the packing gland on the prop shaft which required moving the engine/transmission slightly to make the repair. I moved it back exactly to the same place and after launch, the helm wants to steer to port while under power. Even after repeated re-alignment attemps.
There was plenty of barnacles on the prop which were removed. No damage to the prop was evident. On this boat, the prop shaft sits just a few inches to port of the center line of the keel - therefore the prop thrust is partly on the port side of the rudder. Could this port side helm pressure be caused by a clean prop and bottom? Is this normal while the boat is under power?
