Hi All,
I'm hoping someone will have a solution for me. I have a Universal M35A 30hp 4 cylinder on my E35/3. I have an annoying coolant leak which I can't find. I've removed the heat exchanger, cleaned it, put new gaskets on it - no leak there. I've checked all hose clamps on the fresh water side. I've felt all the hoses for possible leaks in their walls. I can't see or feel any coolant on the sides of the engine block anywhere. Last weekend we motored for about 4 hours and today when I went down to the boat there was about 10 - 15 ml of coolant under the engine (on the starboard side of the centre line). The underside of the oil pan is clean & dry. When I first changed the coolant last year, I drained it from a drain plug on the starboard side of the engine block so I thought it might be comming from there but it's dry & I've tightened it up just for good measure. It got me to thinking - maybe there is a frost plug somewhere on the engine block?
Anyone have any suggestions?
Much appreciated.
Steve Gabbott
E35/3 "Silent Dancer"
Vancouver
Much appreciated.
Steve Gabbott
Vancouver
