jreddington
I'm starting to plan out construction of a frame to hold a tarp on my '84 E-28. I know I should have been doing this last fall but I had a family crisis to deal with and I managed to get just the minimum winter prep done. I'm also not planning on lauching this summer due to some other issues plus I really need to do some major maintenance. There's no way I can get in both the sailing and the maintenance time. So, I'm looking at setting up something that will be on through summer and next winter.
I'm planning on constructing a frame of PVC pipe and fittings. Aft of the mast I'll either wire tie or hose clamp (with proper protection around the stanchion) the PVC parallel to the stanchions and then use 45 deg elbows to loop over the boom (mast is left up). Forward of the mast I'll make a ridgepole to run from the mast to the pulpit and then like aft, run the cross pieces through the ridgepole using pipe fittings.
I'm asking for any hints on the rig and suggestions of proper sizing for the PVC pipe. I'm thinking 1/2" for the cross pieces and 3/4" for the ridgepole. Will this be sufficient to stand up over winter storms with a tarp on?
