From one classic to another?
Firstly, you need to d/l the late model E-34 specs and associated files from the Specs and Docs forum on this site.
You will find that some of your comparisons are, perhaps, apples to oranges.
The change in interior volume will be astounding, for one.
Your question about year and maker -- PSC bought the Ericson tooling sometime in late '90. All of the Ericson 34 models you find will be built by Ericson; PSC re-named this model the "350" or somesuch name.
All of the "things liked" on your list should hold true for the E-34 (or the Olson 34 or even the E-35 mk3, for what it's worth).
On the list of "things wanted" you will not get a skeg-hung rudder. Design-wise, this should be a non issue for any boat. The designer specs out an apropriate size rudder shaft and interior bracing. This was true for the Mull-designed Ranger Yachts, as well. Even the circumnavigating-many-times Cascade 29's and 36's were designed with spade rudders. They never fail, AFAIK. Hun--r rudder shafts, OTOH, *do* fail in blue water, reflecting their lower design strength. (Not a knock on Hun--rs, just commenting on engineering for intended use.)
Note that while there is a *potential* for more strength with a skeg, there is equally a chance for poor glass layup down inside the long pointy mold used to make that skeg... The strength designed into the skeg may or may not be present after production layup... :eek:
When you say "less maint." I am not sure what you really mean. Your present boat is easily old enough to be on its second engine and third set of standing rigging, and second galley remodel, and second rebed of all deck fittings, and refinish of the exterior, and... etc. This is par for all boats -- much worse for low-end boats and normal for Tartans, Valiants, and... Hinckleys. The 15 year old boat you buy will still need regular upgrading, over time...
I have an '88 Ericson-built Olson 34 and enjoy the high build quality. I still have to redo systems that reach the end of their design life... even Harken stuff reaches that point.
It's like when I help a friend rebuild parts of the '83 Hunter he bought for a song... He found that the factory installed one $20. bilge pump. My boat (and the E-34) will have a $250 manual bilge pump and a $135 electric diaphram pump installed; both are rebuildable. My electrical panel has twice the breakers as his. My interior is better constructed and far better designed for life under way. And so on...
You can easily check the PHRF numbers for both boats. You are used to a "plastic classic" fast racer-cruiser. I believe that you would also find the Ericson a good performer on and off the wind, showing the talant of designer Bruce King.
I cannot speak for blistering of other boats, but my '88 had some moderate blistering on one area of the bottom, about 3 X 2 feet, and was not into the laminate -- classic blisters under the gel coat. Faired in '95 -- no problem since.
I have had the keel rebedded due to a seeping bolt, dry since. I reported it here in the maint. forum. You will like having an external keel -- when you hit a rock you only get a divot in the lead to fill and fair -- no glass repair.
I like the T and H sole, I refinished mine because the first owner gave it no care at all.
I am sure you have looked at the Ericsons available in the YachtWorld.com directory. Price will always be what a willing buyer and seller agree on... and I note that there is one for sale in Seattle for about 62K that needs some minor cleaning up. An astoundingly-complete and turn-key E-35 Mk3 just sold in Seattle for a quick $65K. A friend of mine bought an E-32-3 here in PDX this summer for 49k -- it was on the market for less than a week.
The mid to late 80's Ericsons are not "better" than other high end production boats of their era, but they are good examples of how you can have good sailing design, usable interior spaces, and solid construction, in a modern-looking small yacht.
To my biased view, they're are among the last boats before the power-boat-with-a-mast-and-a-condo-at-the-dock-interior trend came into full strength to subvert what remains of the "sailing" market. (end of rant!)
Thank you. I feel much better now...
There are quite a few E-34 owners on this server, and most lurk also over at the Ericson forum at Sailnet.com. I have found this group to be helpful, articulate, and patient with my boat and engine questions. Please ask anything you want!
Best,
Loren in Portland, OR
Olson 34 #8 (owned it 8 years plus...)
