I just replaced my Hurth trans with a TMC 40P Twin Disc trans. The engine's heat exchanger is directly above the dip stick of the new trans. (It was also in the way with the original unit.) I'm wondering if the heat exchanger can be mounted vertically. It is currently mounted horizontally. Mounting it vertically would require a longer run in coolant hose, but the trans would be more accessable.
Has anyone out there mounted their heat exchanger some other way in order to gain access to the transmission?
BTW, the new trans needs to be in neutral while under sail, but that is another thread!
Paul
Paul
