All bolts holding the two halves of my rudder quadrant together are hopelessly seized, including the single bolt going through the quadrant and rudder post. In fact, the head of that bolt is about to shear off because I was able to get to wrench to turn the head, but am certain the shank was still frozen! I'm also certain the quadrant has not been disassembled since the boat was built, and the quadrant being aluminum and the bolt being stainless, corrosion of the two is, again, a certainty. Now that it is hauled, I want to inspect the rudder post, bushing, and attend to some fiberglass work on the rudder since it is showing some surface fractures in the laminate. Access into the quadrant housing is inconvenient at best, and I'm pretty stumped at the moment.
Any ideas on how to extract the bolts, or what the best method would be to separate the two quadrant halves so I could take it to a shop for any bolt extraction and thread retapping?
Given the corrosion, and likely shear of the primary bolt holding the quadrant, I don't really want to just leave it. I also don't what to start cutting in less than ideal space because I may damage beyond repair the quadrant, the rudder post (and therefore the whole rudder), or both!
Thanks in advance.
Thanks in advance.
