Replacement LEDs
Sean Engle
Your Friendly Administrator
Administrator
Founder
Some time ago, I saw a thread of someone looking to replace some of their LEDs in their panels... Of course, I knew I had found a source or replacement some time ago - but could not find it at that time.
This weekend I was moving moving boxes into the attic and found the info...
Check out these people for possible replacements:
http://www.lightingcomponents.com/
They have (had) two that I thought were close: The 36 Series and the 41 Series.
//sse
Nigel Barron
Notorious Iconoclast
Speaking of LED lights, I switched the running lights on the boat I take care of to LED lights. They are so sweet! I also switched the light at the Nav Station, the two galley lights, and the head light to LED. The advantages are many. Those are the lights that get the most use offshore. Also, instead of the standard of 14-16 AWG for light wire, with LED you can use 24 AWG. Below are links for the lights I used.
http://www.lopolight.dk/index.htm
http://www.orcagreen.com/
