Kapnkd I just had a look at their web site and they have TONS of things. Do you know which product is for the Ericson windows?
Yes ...and no. ...Sadly, I'm not at home now in Michigan where I have access to the info you need. I'll be in FL till mid April. I still have a piece of the original seal which helped me find the proper extrusion design.
IF you have pulled a port out and disassembled it, look at an old extrusion end for the design pattern of it then select it from their website.
DO measure the extrusion widths, height etc. as there are a couple similar ones if I recall. ...
Also, a phone call to them might help as I'm sure they've sold to other boaters as well. (The Ericson glass to frame molding is the same as the older Catalina and the Pearson boats.)
IF your luck is like mine, order a few feet more as I screwed up re-assembling one of the larger ports and had to scrap that seal. ;-))
An Extra Thought for You:
How are your aluminum frames? Mine were not corroded but the anodized finish was getting worn out. I cleaned them up, lightly sanded with extra fine sandpaper (220 then 300), sprayed them with zinc chromate primer and finally sprayed them with an automotive silver color touch-up paint close to their original anodized color.
(If you zoom in on the ports in this photo, you can see they turned out fairly well.)
Ohhh - and ...Under the old nemesis
"While we're At It" axiom, we also repainted the headliner while the ports were all out. PITA but sure improved the look below. Just be careful ...as we found out the project NEVER ENDS!
Fair Winds,
kerry
