36C Hull 53
I have read endless posts that discuss the process of replacing teak decking and in all cases it seems to start with removal of the old decking.
The deck I am dealing with is the original from 1978 on a 36 Cruising. Nearly every screw head is now exposed with the heads sitting at or above the level of the wood. I suspect there is only about a 1/4 of teak left in most places?
To add insult to injury, a previous owner at some point decided to put on a thick coat of varnish everywhere.
My question for the forum is, is there any other solution then ripping up all the old teak, dealing with all the resulting screw holes and then replacing?
Is it possible to somehow seal the old stuff and just put new stuff on top of it? I suspect the answer is "no" :-(
