Replacing Vinyl in Berths
ChrisS
Does anyone have any experience replacing the old vinyl that lines the hull in the berths? I'd like to put new foam-backed vinyl in the quarterberth to start, and I am wondering if anyone has tackled this project and has any adhesive recommendations and/or techniques they could share.
Also, I will remove the cabinet at the head of the quarterberth to do the job. How do I replace the teak screw hole plugs? Put new ones in, and then chisel off the excess?
Tom Metzger
3M spray adhesive
Merry & Happy to all - :egrin:
I had good luck using 3M spray adhesive a few years ago when I did it on a previous boat. It's available from any good hardware store.
The worst part of the job was removing the old adhesive and foam. I used acetone and a good respirator.
Your method works well for the plugs. I'd advise against using any adhesive.
Jerry
Inactive Member
In the past
I've used contact cement on headliners, vinyl and other fabrics. Contact cement gives you a lot of open time while you move things around before final attachment. I use wood dowels and wax paper to keep the two surfaces apart while everything is being lined-up. When things are lined-up start at the center and work out towards the edges to prevent air pockets from forming.
As for the teak plugs - I use a dab of glue, trim down to the surface and then sand smooth.
jkm
Chris
I just used 3m spray-it was very easy to apply.
When I replace plugs I avoid glue. Once you seal it, they shouldn't pop out.
John
