I would (eventually) like to set up a reefing system with lines that run back to the cockpit. I don't mind going up to the mast to hook the luff cringle, but would like a second crew person to be able to run the halyard, topping lift, and reef outhaul / leech cringle lines from the cockpit.
I'd like to set up something like Ted's (described here: http://www.ericsonyachts.org/infoexchange/showthread.php?t=4769) but could really use some pictures of the setup at the gooseneck and foot of the mast. On my E27, I would probably run everything outside the boom, unless I defer this project to the winter and a boom overhaul.
I think I'd like route the reefing lines, halyard, and topping lift through clutches, keeping the reefing lines on one side and the halyard / topping lift on the other.
