    EY.o April Zoom Meeting
RF drain, grounding question
Tin Kicker
I'm comfortable with those concepts and agree. But why then, aren't our DC systems a "closed loop" between the batteries and the gadgets/load that use power? Couldn't we only have the the AC system grounded to the water via the engine block? The shore power battery charger would be the only AC/DC crossover point.
If you ever got off a car or airplane that has had a static load build, you'd appreciate the desire to ground vehicles. (rare these days because so much carbon is in the tire rubber.) If God forbid you ever have a basket dropped from a helicopter the LAST thing you want to do is touch it before it touches the water, because the discharge can knock you flat. We really don't want the vehicle to have a charge different than what it comes in contact with, yet are running aluminum and stainless rigging through the air mounted on plastic boats. Having static occasionally discharge itself can also really do a number on radios and other electronics. Another reason is that boats may receive energy from lightning or other sources without even being directly hit and we want the easiest way for that to move to ground, especially if there are possible fuel vapors. A professor specializing in static electricity told me during the TWA 800 investigation that if you have a flammable vapor, nature will find you an ignition source.
The Radio Frequency Isolation (RF drain wire) issue remains mysterious to me.
I find my black DC ground wires connected to a common post connection, and then I run my new green "RF drain earth ground" wires to the same common connection, isn't this just redundancy? Maybe that's the whole point.
It's all again part of trying to not have a difference in potential between different grounded parts or wires in a vehicle. Remember that even 1/0 battery and ground cables have a unique resistance in each piece. If you have two lengths of 16 AWG both hooked to the same ground, there will be a temporary transient charge difference. For example if one is to a nav station incandescent bulb and one to an incandescent bulb at the top of the mast, flipping the mast light switch off could flicker the other bulb. Or create a pop sound from a radio speaker.
Some electronics manufacturers do put more emphasis on preventing ground loops than others. My own guess is that the ones with more emphasis are going to be the ones which have experience in more of the larger or more complicated systems, such as commercial use, while the lesser have more of a consumer/simple background or focus.
eknebel
For systems in small boats, the rf ground is overkill, unless you have upgraded your radios so that the v berth has been converted to a communications room. In that case, a separate rf grounding system is then needed, like big boats have. The rf grounds purpose is to make sure that any reflected "AC" from radio transmission is dissipated. This rf grounding keeps the other electronics(that are all connected by DC ) from acting possessed each time the mike is keyed. So, just put the rf ground to the black(negative) DC that powers the device. It is common to put the rf ground to DC negative, Raymarine says to use DC neg in some of their install directions.
I am staying away from the rabbit hole of bonding and "grounding" discussions, other than to reinforce others comments to do maintenance on electrical connections. Especially if troubleshooting a electrical problem. Not that we don't have enough to maintain already!
goldenstate
Thanks Ed! You've supported my suspicion that my newly-wired 3rd-leg run of green RF ground wire with separate connection to my common grounding point, is redundant, but it got me away from my kids zoom classes for a couple of days this week.
JLapp
Sorry to dig this thread back up, but I have a lot of electrical demons to chase down on my new E27, which is powered by an outboard. I'm not sure how anything is grounded. I came here for answers and only have more questions. ;-) haha I guess it's time to dust off Nigel Calder's book again.
eknebel
I don’t remember if Nigel covers outboards. Think of the outboard as a electrically noisey, spikey (technical term) alternator. If your demons are summoned by running the outboard, look to noise suppression filters, many brands are sold.
JLapp
Good to know, I think my demons are house circuit related and certainly the old batteries are not helpful. The 3 batteries are dated '13 and there is a tape on there about some special water used in '14. I'm just going to get new batteries. I'm amazed they are working at all!
I want to go through it all and switch over to LED, but now I'm wondering how to ground out the system with no steel shaft out into the water? I'll trace through the current layout in-case it's already solved, but I'm preparing myself for the worst case.
goldenstate
The 'special water' from 2014 you reference is no doubt distilled water for your lead acid batteries. The water gets consumed by the battery as it is used and recharged and needs to be replenished.
If you can pry open the lids on your battery and see spaces below, you should go to CVS or a drug store, spend a dollar fifty on a gallon of distilled water and top up your batteries before you replace them. This needs to be done on a regular (6-12 month) basis depending on use. Look it up on Youtube. Don't overfill.
Try the easy cheap fix before you buy new batteries. I did this, and all of a sudden my batteries held charge much better(!)
$.02,
Tom
eknebel
Jlapp,
It is common to mix grounds and bonding up, but they are different. Christian posted a link to an excellent article previously in this thread. However your boat is bonded, it has worked for this long, so choose your battles carefully
frick
FYI
An RF (Radio Frequency) Grounding system in a boat is very different that your 12 volt negative ground.
If you are running Marine SSB or a Ham Radio your antenna needs a RF Ground to work as a counterpoise for your HF Antenna.
Sometimes it may be a plate under the boat. Sometimes it might be is a Sheet of rolled copper that run in the bilge or in a locker.
An RF ground will also keep stray RF out of your other electronics which is why they put an RF ground on the device.
Rick
Tin Kicker
JLapp -
You mention demons but not what they or the symptoms are.
Regardless, the first step I usually go to before spending money is to open every connection related to your issue, clean them including with contact cleaner, and reassemble with a touch of dielectric grease.
JLapp
TK, I've traced out a bunch, but I'll do the cleaner and grease next. I'll stop hijacking this thread and start a new one about my issues since they are not RF related. Sorry.
"You're Grounded!" now has a whole new meaning, and I really wish to thank this group for improving my psyche.
(Sorry... for reviving this thread, however, it seemed to be the most theory-based discussion, yet found, regarding grounding: I may be wrong)
This thread was a recent discovery, while searching for "grounding brush" and I learned here it's also called a "shaft brush." This ground-breaking discovery lead to @Christian Williams most excellent recommendation of the West Marine article, which was an excellent N.Calder-like overview.
However, it wasn't until I witnessed @tilwinter Tim's earth-shattering diagram that Nirvana on an Ericson does truly exist. Holy Gravity!
I'm not sure if "thanks for posting that Tim" is in order, but heaven on earth might truly float! (P.S., Tim, your image, "Marine-Grounding-1.jpg" doesn't seem accessible today.) Tim, your statement here regarding vehicles, but can it be applied to vessels? "try(ing) to not have a difference in potential between different grounded parts or wires"
Backstory: I'm working through the electrical "harness update" on our still new-to-us E32-3 vessel (which other owners probably completed at least 5, 10 or 15 years ago). Yesterday, I affixed the BlueSeasS 4-terminal 1/4" busbar and attached a #1AWG-wire "jumper" from the battery-to-block grounding point to one BSS busbar (pic).
I recognize my vessel does not have a "Common Ground" and Jeff Cote may believe (see below) few vessels ever reach grounding perfection. Sounds comforting...?, more like complicated., as he says.
QUESTION: How far away is my setup from perfect?
Is my boat burning now? ;)
My plan, I seem to think I'm following in the flipflops of others, is to ground smaller diameter harness/fuel pump, etc grounds to the busbar.
Any guidance?
Reference: Screenshot from
When I began taking more interest in the theory of grounds and grounding, I was like.... What a rabbit hole! Then, I recently listened to Pacific Yacht System's Jeff Cote, who shared: "I could do a video on grounds that could last two hours i bore most of you, BUT it is very interesting, because it's so freaking complicated."
same ol' story in sailing...lifelong lessons to be learned.
(I don't even wish to touch "RF Grounding")
There are so many nuggets in here that I have yet to discover that I'm glad when someone revives an old thread. It both concentrates and expands the knowledge base. This one is new for me so thanks!
