Running backs
I assume you are talking abount a genoa staysail to be flown under a high clewed genoa/jib top reacher as opposed to a spinnaker staysail, since this was the common set up for the E 35-2 in the early days (and is still awesome in the right conditions with the right headsail). Unless you are doing some serious offshore voyaging I would not worry about getting running backs on this boat-as long as you are taking the time to set up the rig correctly using the forward and aft lower shrouds. The mast section on this boat is pretty beefy, and can handle these kinds of loads. You just want to be sure you haven't set the aft lowers so tight that the lower half of the mast is pulled aft. As long as the forward lowers are a little tighter than the aft lowers so you have just a hint of prebend you should be fine. I would suggest a backstay adjuster though, and if not, I would make sure you have enough backstay tension on to keep the mest from from being pulled forward out of column when the staysail is flying.
When you get the staysail, go sailing and sight up the windward side of the mast. As long as it is straight or has a slight aft bend all the way up you are OK. What you do not want to see is any out of column effect, or have the staysail pull the entire top of the rig forward. If the top section of the mast is slightly forward, but the overall curve is a gentle aft bend you will be fine.
You should have no trouble setting the rig up to be fine with this sail combo without runners. The later E boats with lighter, bendier rigs (32,34,35-3 and 38) would be better off with runners if one were to set up a double headsail rig like this.
I am not saying it would be bad thing, or that it may not offer some fine tuning advantages, but it should not be needed unless you are doing long offshore passages where this may be your primary headsail in very severe conditions. All of the genoa staysails I have built for E 35's, or seen used, were to improve reaching performance in the 5-25 knot wind range (and flown underneath headsails ranging from 170 t0 110%), and very few of them had running backs set up. Check out the brochure picture on this website-that is how they are used. No runners in that shot, and thatboat (Aquarius) was a successful racer back in the day.
If you did rig them, the inner forestay (if used-you can also build one with a built-in dyneema luff and free fly it, but it requires a good bit of halyard tension) would attach to the front face of the mast just above the pole topping lift/staysail halyard exit slot (or about midway between the spreaders and the masthead). The runners will attach to tangs on the sides of the mast at the same height. I would use dyneema or other low stretch line for the runners, and lead them to a block on the outer genoa track at a point just aft of the wheel (maybe 2-3' forward of the stern). You can lead them to a free winch on the windward side of the boat. They will only require enough tension to either stop any pumping of the mast (not too likely in most conditions), or to bring the top half of the mast back into column (even less likely with this mast section).
Good sailing!
S
