Reefing
Hi,
I have an E-27, and over the years have sailed it in all kinds of stuff. But, truth be told, it is hard for me to get a fix on what your problems are from the explanation you gave. Probably just a slow brain on this end.
What I am getting is that you release the main halyard from the cockpit, so my guess is that you have a winch on the cabin roof and the main halyard goes through stopper (clutch) of some kind. That would--by my way of thinking--take care of the luff of the sail. If reefing is at hand, my assumption is that you have already tightened the outhaul all the way. There needs to be a reefing line that is dead-ended to an eye strap. My boat has a stopper knot at that end. The line leads from the eye strap through the cringle at the aft end of the first reef (the new clew when the reef is in) then down to a cheek block that changes the lead of the line so that it goes forward. When you tension this line you take the belly out of the foot of the sail and flatten it. I can do mine by hand or, if I want, lead it to a winch on the mast for more MA. Then, you can use the reef lines (nettles) to make everything shipshape, tie up the bunt. The eye strap and the cheek block have to be positioned aft of where the reefed clew will come down to the boom, so you get rearward pull.
I hope this helps. Reefing is pretty much the same on all boats, though I have sailed my own boat mostly. What I have found is that when it gets really windy, 25+, I do better from a control and comfort standpoint with just using the working jib by itself. The last time I used that sail alone we had a ball in 35+, screaming around lower Tampa Bay. You could smell the testosterone from 1/4 mile away!
Morgan Stinemetz
