Sven
Seglare
I just got an answer back from Paul at Foss regarding upgrading Senta's rudder to bigger than IOR specs.
He suggested either using Bruce King's modification or a considerably higher aspect ratio rudder that they have installed before on other boats. BK's modified rudder has a larger surface area than the Foss alternative (8+ sq. ft vs 7+ sq. ft). The higher aspect ratio of the Foss alternative looks as if it would still be more effective than the BK redesign despite it's smaller surface area and it would also be further down in the propwash for control under power.
The higher aspect ratio looks less substantial than the BK design and I wonder if that should be a consideration for our planned off-shore use ?
Thoughts and opinions are most welcome.
-Sven
-Sven
