Roger Ware
simpler solution?
I very much appreciate all the suggestions, but I wonder, instead of all the complex siphon break arrangements that have been proposed, or the check valve which seems to come with its own baggage, why not just close the bilge thru hull (which I will need a valve to do) when sailing in strong winds, and leave it open the rest of the time? The E38 200 is a dry boat when sailing and takes little water into the cockpit, let alone into the bilge. Simple, cheap, and should be 100% effective (OK I admit that you have to remember to open it afterwards!). Wouldn't work for blue water sailing, but I don't do that anyway.
Roger
Roger
