I am a new E32-3 owner. My boat is overall in excellent shape. There are some issues that the passage of time has brought about. I would appreciate advice as to the following issues:
1. Leaking side ports. The ports on the aft of the cabin show evidence of leaks in the past. After 25 years I suspect that the material used to seal the ports may have given up the ghost and need replacement.
Q: How difficult is it to remove the ports and rebed them? Has anyone done this? Is it expensive to have a boat yard do it?
2. Lewmar Hatches. Both lewmar hatches on the deck are crazed. Instead of removing the hatch frames and replacing them, I would prefer to replace the hatch tops only. I have an email in to lewmar on the question of whether the tops are available.
Q: Does anyone have any thoughts or advice on this issue?
3. Stove. The present stove is a two burner alcohol stove with an alcohol oven. I will probably convert to propane.
Q: Does anyone know if there are conversion kits to convert stoves and ovens from alcohol to propane? I suspect this may depend upon the design of the stove. I have heard the suggestion to remove the stove completely and replace it with a micowave oven which could be operated by 12v batteries through an inverter that will convert the 12v to 110v. I would welcome suggestions along those lines also.
4. Switch panel indicator lights. At some time the boat has suffered a lightning strike which blew out some of the small red indicator lights that illuminate to indicate that an electrical device is switched on. These lights are located just behind the chart table.
Q: Does anyone know the source of replacements for these small red indicator lights?
5. Corrosion on the mast and boom.
Q: Does anyone know the process for addressing the issue of small spots of corrosion on the mast and boom which have removed the paint?
Any input or advice would be appreciated.
