Tom Metzger
Since Xanthus is gone I have been told by the admiral that boating stuff must to go. Please don't ask for it to resell. It's for fellow Ericson owners.
Some of it has "limited" value, but some of has real value. All of it goes for the cost of shipping, but you will owe me a martini. First come first served. Email request to tometz11 at gmail.com.
Engine control handles. These were changed out by the original owner prior to 1996 when I bought it.
2 Autohelm 4000 mounting brackets. Guest helmsman occasionally sat on my autopilot which was too easy to do. I maintained a supply for easy replacement. I doubt that they are still available from Raymarine.
Antenna/GPS rail mount
Guest MOB xenon strobe light. It worked in 1997, but I don't have a lantern battery to test it. It hangs from stern rail and starts when it floats right side up.
West Marine hand bearing compass. It's the latest thing... it replaces your chartplotter. Works by magic... no batteries.
Barient 27st winch bearings. They may fit other winches??? I replaced the bearings in both of my primary winches and marked these two as still good.
Low current windlass switch - new. It came with my windlass, but I used a high current switch.
Coolant overflow tank caps. Twenty years or so years ago the OEM caps failed en masse. I got 25 caps free, not worth the paper work, which I gave away (postage was cheaper then). The demand dropped and I still have three left. I'll still pay the postage if you need one.
8.5x9 Johnson/Evinrude 5-6hp prop part # 390237
Schaefer 60mm (2 3/8") block w/ 5/16" shackle for wire or rope. Anyone still have wire rope halyards?
