Source for backing plates?
ChrisS
Hello All--
I'm going to rebed all stanchions, and the pullpit and pushpit, before the rains hit, and I am wondering if anyone has a good source for backing plates. Rigrite sells both aluminium and stainless blanks. Does anyone have another recommendation on where to find backing plates? And do 1970s Ericsons use a "standard" plate, or must I drill out blanks?
I know I could cut out my own plates from Starboard, but I am looking for a lower profile look.
http://www.ericsonyachts.org/infoexchange/showthread.php?t=3371&referrerid=28
Mentioned in this thread, and others...
is the commercial product called "FR4/G10" which is fiberglass cloth and epoxy resin layed up in many thicknesses, your choice. You can source it from plastics suppliers like TAP or online at MaMasterCarr.
I was using something like 3/8" which is overkill for this, but comforting!
That, plus the factory ss backing plates.
Another photo of the underside of part of our deck at this link:
http://www.ericsonyachts.org/infoexchange/showthread.php?t=3509&highlight=stanchion+upgrade
See photo in reply #3.
The epoxy plate is set in a layer of epoxy mush, and you will need a prop or two to hold it tightly in place while the epoxy kicks. Working overhead, under the sidedeck, is SO much fun!
gareth harris
Alternatively, any machine shop will easily be able to make up a new backing plate out of stainless steel.
If you will likely have landlubbers on board who try to pull the boat around/tie off/completely abuse the stanchions, you may want to do a more thorough backing than just the low profile - sandwich something soft, like 3/8" plywood, between the deck and hard backing, to absorb the shock load. Otherwise a hard material such as stainless steel or one of Lorens suggestions will be fine.
Gareth
Freyja E35 #241 1972
